Thyristor as switch
38,731
Yes, i understand this so the toggle button will off so the circuit power will off as well the thyristor
No, apparently you don't understand.
An SCR operates as a latch that will keep conducting even when the gate signal is removed.
It only stops conducting when its anode-cathode current stops.
Thus the switch to turn off the SCR needs to be in series with the motor and SCR.
Reloadron
Joined Jan 15, 2015
7,922
Your power sources need to share common, I covered that. I gave you a basic schematic. I am sorry but most of the people who would like to help would appreciate a schematic. Reading a crayon picture is difficult at best. I have no idea what the red button is all about? Would that be N/O or N/C? As mentioned, once you turn a SCR On in a DC circuit it's on and remains on till the load power is broken. I have no idea what you are doing on the gate circuit? Go back and look at post #10 and work from that. Label your parts as to pinout and what the switches are.
Ron
Ian0
Joined Aug 7, 2020
13,248
I'm not absolutely sure about thyristors and brushed motors. Will the commutator cause enough interruptions in the current to de-latch the thyristor? Does it depend on the commutator and the design of the brushes?
Ian0
Joined Aug 7, 2020
13,248
Yes, it can be done that way, but why?
Now you need two power supplies, and one is floating awkwardly at the cathode voltage, which could be either0V or 12V.
Momentory
Joined Sep 4, 2022
101
To see the post on #10 posted by Ron, so you just need one voltage.
Yes i know and i understood how to use it with one power supply, but i want to learn to use two power supply
As some applications will need more than power supply.
I just want to learn to use more than one power supply
ScottWang
Joined Aug 23, 2012
7,505
So you need to know the Vg of SCR, you should compare two circuits.
