Thyristor as switch
Momentory
Joined Sep 4, 2022
101
I have two connected circuit
  • 12v dc battery
  • 12v dc motor
  • Thyristor ( input current max gate current 0.05 ampere) - (1.3v max gate voltage)
  • Resistor 39 ohm
  • 1n4007 diode
  • 1.5v dc battery
The thyristor will be the switch for this circuit
My question is very basic but i want to understand how it works
In the circuit that has the thyristor
What is the voltage of this circuit ( A ,B), Is it 1.5v or 12v since the circuit connected to both circuit?
Ya’akov
Joined Jan 27, 2019
10,285
What do you mean by “voltage of this circuit”?
There is no special attribute of a circuit called “voltage”. Components are identified by ”voltage” to indicate nominal supply voltage, nominal output voltage, or nominal operating voltage.
I don’t know what your question means because a circuit doesn’t have a voltage, it has many voltages wich can be measured at different points. Could you clarify?
Momentory
Joined Sep 4, 2022
101
Sorry for this
I edited the post
A is the gate of thyristor
B is connection point between both wires
Alec_t
Joined Sep 17, 2013
15,152
Have you checked with the datasheet that the cathode and anode connections are the right way round for your particular thyristor? The centre pin of a thyristor is usually the anode.
That's confusing. 'A' conventionally denotes the anode.
No A or B in the pic?
Momentory
Joined Sep 4, 2022
101
"A" is not referring to the anode of the thyristor
It is just a word to point the points i want to measure the voltage from
A and B are points not referring to thyristor anode or cathode or gate
Battery negative wire goes to andode (middle pin) and wire from cathode goes to the motor
BobTPH
Joined Jun 5, 2013
11,631
Your circuit is incorrect. The cathode (pin 1) should be connected to both battery negatives, and the motor negative should be connected to the anode(pin 2.)
Reloadron
Joined Jan 15, 2015
7,922
Below is a basic schematic of a SCR / Thyristor circuit.
SW1 is a N/C push button switch, SW2 is a N/O pushbutton switch. Momentary press on SW2 will start the motor and momentary press on SW1 will stop the motor. The anode, gate and cathode of the SCR are labeled. The resistors form a voltage divider for the gate voltage. Now using this example what exactly do you want to know.
Ron
Momentory
Joined Sep 4, 2022
101
Ron
I need the thyristor to has its own battery, but i do not understand why my circuit is wrong
BobTPH
Joined Jun 5, 2013
11,631
Your circuit is wrong because the thyristor anode and cathode are reversed. Do you understand that it only conducts in one direction?
Reloadron
Joined Jan 15, 2015
7,922
OK your circuit reflects a TO220 case for your thyristor. Normally less a data sheet to look at it would look like this.
Now just note the pinout for Cathode, Anode and Gate. This is what everyone is getting at. To gate it ON the gate needs to be positive with respect to the cathode. Yes, you can use a separate power source for the gate as long as they share the same common.
Ron
