drjohsmith
- Joined Dec 13, 2021
- 1,653
Like the idea of the farm fence ,,Of course you can also add a single chain, or thick steel cable, anchored to an eye-bolt screwed into a garage structural part, or into an anchor in the floor. Not totally unbreakable, but will take a few minutes to break. Threaded through the frame opening of all the bikes. Breaking or cutting that will take at least a minute, and if the alarm system is at least 120 Decibels it will provoke a panic among the bad actors. Flashing strobes also make it harder for them to focus. AND if the alarm triggers before the door is opened very wide they might not even get inside. And the good ting about such an arrangement is that if it is triggered accidentally no injuries result. An actual farm livestock fence charger hooked to the cain restarining the bikes could seroiusly slow the bad actors a bit more. Painful but not lethal.
but in case others look, certainly in the UK,
doing so is looked on badly by the police, and you will be arrested as "unreasonable force" esspecialy if youhave not put big light signs every where !
Ask me how I know
