Me tooI hope this describe the behavior of the system
From #38:
If the system is in the TEMPERATURE HIGH (center right) state because of a high temperature reading, what happens if the FIRE sensor activates? You indicated that FIRE had a higher priority than HIGH TEMPERATURE.Exercise : Complete each tasks as per their priorities
Task list
1) Monitor for fire- Priority 1
2) Monitor for fault- Priority 2
3) Start motor , wait, stop motor - Priority 3
4) Monitor for room temperature range- Priority 4
Ideal state: Motor start for 1000ms and Motor stop for 1000 ms. repeat process
Event : When fire sensor detects fire in room , Stop motor
Event : When proximity sensor detects any objects, stop motor
Event : When room temperature is high than set temperature, stop motor
On a separate topic:
It would be helpful to number the states to be able to discuss them easier.
Please consider dropping your camera resolution to something less than 3.5MB per snap. Gigantic pictures make it difficult to edit the diagram and post fixes.
