Hi.its on y conectit.
If you can post a close up of the motor plate and show the terminals with the cover off.
Most likely connectable in delta.
Do you have a motor that runs on 380V and you want to run it on 220V , post pics of the motor and name plate.
Can you post a picture of the name plate? It should have the information you desire.
Hi.Although it shows Star/Delta on the plate, It only show one voltage, But the fact is also shows two current levels I am guessing it can be run on 220v delta, what I would do is connect in 220 delta and monitor the current to see if it conforms to the plate.
We really need to see an inside look of the terminal box on the motor.
That's the pictured of motor.
Hi.
Yes that shows the star delta arrangement but it appears that the motor could be being switched between the two, possibly for starting.
I don't see any customary star straps across the terminals?This is not star/delta but as we can see the motor is connect in star but the motor has two speeds.
