Please help to to control a three phase motor
tylersmith66674
Joined Jun 8, 2022
7
A star delta starter is used to control a three phase motor. The line conductors from the starter to the motor are wired in 4mm copper conductors and have a resistance of 87.5m0.
A load consisting of three identical coils with resistance of 11Ohms and inductance of 50mH are connected (i) in star, and (ii) then in delta to a 400v 50hz 3 phase supply. Determine the total power dissipated in each case.
You must use the Xl=2 π fl formula.
Ps= √3 x Vl x Il x Coso
Papabravo
Joined Feb 24, 2006
22,113
You need to show us what you have done so far so that we know where the problem is. How about starting with an accurate drawing of each setup.
