So.. long story short... I bought a 2nd Samsung monitor and while setting it up I somehow mixed the power supplies up, of course they have the same connector.... The new monitor worked fine for 15 minutes, then went black, right side grey stripe... the backlight still comes on but the power LED indicator does not and the monitor won't turn off unless you unplug it.
I know enough to be dangerous, I have a multimeter... any suggestions on testing... I am going to cry in the corner for a little bit then return to see if anyone has any kind words of support to share.
The Monitor... C32G55TQWN
The WRONG power supply A5919_RDY 14 V 35 W 2.5 A
The RIGHT power supply A3514_FPN 19 V 59 W 3.11 A
The board to test... CODE BL41-028038 MODEL BN4102806
