thickening battery acid????
Poor old sod
Joined Jul 25, 2017
193
I have a wet cell auto battery, and it is subject to vibration and small shocks. Is there something I could add to the acid to thicken it to provide plate support/damping? IE: a DIY "gel cell"?
bwilliams60
Joined Nov 18, 2012
1,450
There is nothing you can add to a SLA battery to thicken the electrolyte. A good container with proper hold downs will minimize movement and reduce vibration. Next up would be a deep cycle battery which uses thicker, larger plates and better grid substances which strengthen its construction. Again, hold downs are a must. As others have said, AGM and GEL batteries are best for this application as they are built to deep cycle and have limited or no liquid movement within the cell. The only constraint here is your charging voltage and both of these are finicky when it comes to that. Those are your choices for now.
Poor old sod
Joined Jul 25, 2017
193
thx to all. it's a little clearer now. just that the cost of deep cycle is so high......$300-$500 + depending.
GopherT
Joined Nov 23, 2012
8,009
But the transfer of ions is critical to the successful current-carrying capacity of the battery. Gel cells use very weak gels that allow ion mobility. Not simple chemistry -especially a gel that is acid stable.
