Ok I see it too but isn't the same as I posted earlier?
Isn't what the same as what that you posted earlier? You need to try to be more explicit so that people aren't always having to read between the lines of what you are saying.Ok I see it too but isn't the same as I posted earlier?
Agree - but it is a useful trick - a bridge is a common circuit and you can always split it like this.But it seems like a good approach when you can see a way to break the circuit up that way. Don't know how often that is possible, though.
You should try to understand why it is different. Mine is an exact equivalent circuit relative to ground (you seem to have moved that), it will correctly (and easily) give you the voltages at the nodes at the ends of R5 with R5 present, removed and shorted. I'm not sure which are needed but all seem to have been discussed in this thread.Ok I see it too but isn't the same as I posted earlier?
The nature of the signal source is irrelevant. If it weren't, then what would you do if you had a both a voltage source and a current source?Let's clarify some theoretical aspects: Thevenin's theorem is used when the source signal is voltage. If the signal source is current Norton's theorem is used (rarely encountered in practice).
| Thread starter | Similar threads | Forum | Replies | Date |
| I | RC - Thevenin Equivalent Analysis | Homework Help | 12 | |
| F | Thevenin HW Example | Homework Help | 1 | |
Thevenin Theorem problem | Homework Help | 1 | |
| L | Question 7 from Thevenin worksheet | Homework Help | 10 | |
calculation of thevenin equivalent circuit | Homework Help | 6 |
