calculation of thevenin equivalent circuit
amPOP
Joined Nov 11, 2024
I should find thevenin circuit equivalent of this circuit, but I don't know how I can approach it.
I ask you please if you can tell me how to proceed
WBahn
Joined Mar 31, 2012
33,257
Certainly you can see that some of those resistances can be trivially combined. Start there and at least show a simplified circuit that has those taken care of.
amPOP
Joined Nov 11, 2024
Could this be a start? Is there anything else that can be simplified? Sorry, I'm just starting out, can the two resistors on the right of the diagram be considered in parallel and replaced by a single 2Ω resistor?
ericgibbs
Joined Jan 29, 2010
21,589
Hi am,
Looks OK to me.
Remember your current and voltage sources are considered ideal
An ideal current source has an infinite internal impedance and an ideal voltage source has a zero internal impedance.
Post your best attempt.
E
The Electrician
Joined Oct 9, 2007
2,986
Hi ericgibbs! thankyou for helping me,
can i consider those two resistors in parallel right?
Resistors in parallel with voltage sources such as the 8 ohm and 2 ohm can just be eliminated. Resistors in series with current sources can be replaced with a short. What do you get after those simplifications?
You have a controlled source. Is it a voltage source or a current source?
Attempt at humor. This is a problem that helps you decide if you should be an Electrical Engineer, If you're eager to solve it, and are a little bit on the spectrum (helps your ability to focus on a problem for a long time), you're on the right track.:D
