Thevenin of a voltage divider
MikeJacobs
Joined Dec 7, 2019
232
So i have not done this in a decade and trying to remember this. apparently im doing something wrong.
I was taught thevnins therom using the the short circuit method.
Vth = Isc*Rth
Take a simply voltage divider where R1 and R2 = 10k
The point of interest of A and B commonly called would be across R2.
So i was taught or at least i think i was to do the following.
Find ISC as if points A and B were shorted.
So in this case using a 15V supply i would have
15V / 10k = 1.5 mA is ISC
Then Vth would be what is the voltage at point A with A and B open, well, that in a voltage divider that is just the supply voltage of 15V.
So vth = 15V and Isc = 1.5 mA
So rth = 15V/1.5mA = 10k of course
So the eq circuit is a 15V supply with a 10 k resistor.
What did i do wrong here?
38,804
Sorry, I go lost between R2 and points A and B.
Schematics are the language of electronics.
Could you post a schematic of your circuit?
For a voltage divider, the equivalent voltage would be the divider output voltage with no load, and its output resistance would be the value of the two resistors in parallel, so neither of those values appear to be correct.
MikeJacobs
Joined Dec 7, 2019
232
Typically people talk about a point of interest in the circuit where you want to know the equivalent. Sometimes called A and B
In this case, im defining points A and B across R2.
aka the normal place we talk about output on a voltage divider.
Make more sense?
So as i was taught
Vth is the open circuit voltage from A to B
Isc is the current flowing when A and B is shorted
and Rth is
Vth / Isc = Rth
So where did i go wrong?
MikeJacobs
Joined Dec 7, 2019
232
Which is 7.5V.
(Remember it's a voltage divider).
which is 1.5mA
Which is 7.5V / 1.5mA = 5kΩ.
Do you see now?
I dont get it
How is the open circuit voltage from A to B 7.5V?
Its open circuit, therefore no current flowing therefor no drop through R1?
kaindub
Joined Oct 28, 2019
183
You could consider it either way for this simple circuit. In more complex circuits you'd probably consider it as part of the source in order to calculate the following stages.
