Hoping someone can help.....This has to do with a simple THEVENIN CIRCUIT with only 3 components.(1) AN AC SOURCE VOLTAGE AT 40 VOLTS ZERO DEGREES (2) AN INDUCTOR XL=30 (3)A RESISTOR 10 OHMS
All three are connected end to end in series....WHAT I WANT TO FIND OUT IS THE THEVENIN VOLTAGE and the THEVENIN IMPEDANCE
CAN YOU GIVE ME THE ANSWER IN BOTH POLAR AND RECTANGULAR FORM AND HOW YOU DO THE CALCULATIONS
*THE LOAD OF THE CIRCUIT WOULD COME FROM ACROSS THE RESISTOR*
