If this is just a 'mundane' thermometer, an RTOS is complete overkill. The code would be very simple and short. What is the 'requirements' for the project? I need more specifics in order to help. A block diagram of what you have in mind would also be helpful.no its just a mini project without tools so far
meanwhile i have to work first with micro c and isis using osa rtos and pic18f452 to make the thermometre work
ok, thanks for that detail.In this project, a thermometer is designed. A temperature probe can be used to measure the temperature. The voltage to be measured is applied to one of the analog inputs of a PIC18F452 microcontroller. The microcontroller reads the analog voltage representing the temperature, converts it to digital, and then sends it to the PC via RS232 serial communication by pressing the push button. A LED diode is added to flash every 600 milliseconds. A PIC 18F452 with a clock frequency of 20MHz is used. The read() task is executed every 600ms and flashes the LED on the RB0 port pin to indicate that the system is working. The measure() task measures the voltage value on an analog input representing the temperature. The send() task scans a button press and writes the temperature value on the Hyper Terminal chain via RS232.
The work required is to provide a complete description of all the tasks and services of the OSA RTOS that will be used based on the specifications. Write the code for this application using the mikroC software for PIC and the OSA RTOS services while adhering to the data in the specifications. Create the schematics for the application. Design an experimental platform for the application using ISIS software. Simulate your application using the debugger of the mikroC software and the ISIS software.
By Prof, I suspect you mean 'professor'? I take it this is some sort of assignment for college? Do I have that correct?the prof didnt mention any type of probe
but i think that any type can be appropriate
what do recommand
Hello there,i have a project my work is to do a thermometre rs232 with microcontroller pic18f452 and the services of osa rtos using micro c ans isis i didnt know how to start can someone help me doing it
