Thermocouple and Thermopiles of special differing wire metals stats?
Status
Not open for further replies.
russwr
Joined Aug 29, 2017
123
Looking for some data regarding thermocouple specs of platinum and gold, platinum and silver, and silver and gold, as end to end with joint. The ratio of resistivity seems to be about 1:3 . Thermopile would be all three in series. Tests were made long ago but with little data, in relation to transmitter frequencies applied over joints that had caused multiplication of frequencies harmonics and inharmonics as causing nodes interference. These metals were said to be the best for proper ratio.
Danko
Joined Nov 22, 2017
2,153
Metals:
Ag 6,5 uV/°K, 1.59x10-8 Ohm*m
Au 6,5 uV/°K, 2.44x10-8 Ohm*m
Pt 0 uV/°K, 11x10-8 Ohm*m
Thermocouples:
Pt+Au 6,5 uV/°K
Pt+Ag 6,5 uV/°K
Ag+Au 0 uV/°K
russwr
Joined Aug 29, 2017
123
The metals have different gauges sizes as wire. Certain gauge of each could be figured so as there is an exact ratio of thirds for resistance so as they could be used in bench experiments , as was done in 1890's by Mr. John Keely. We call them thermocouples, but would be expensive in these days.
Danko
Joined Nov 22, 2017
2,153
Over Unity System
John W. Keely had shown demonstrations in 1890's Phil. Pa, of lifting effect (no gravity) with resonance frequencies and harmonic ratios using array of tuning forks and multiplication of higher vibrations on heavy metal spheres .His "transmitter wires" of gold, platinum + silver, are now called thermocouples and thermopiles. Witnessed by engineers, newspaper men, and investors at that time. Tesla didn't like Keely since Keely got more investor's money than he did.
https://permies.com/t/232365/Unity-Systems
Status
