Thermal capacitance and resistance of conductive material
kalemaxon89
Joined Oct 12, 2022
389
Hello everyone.
In my spare time I am working on this project:
I have a strip of conductive fabric that, bound around the place, gets hot when current flows.
In addition to the measurements you follow with instruments in the lab, I would like to try to simulate its behavior on LTSpice with the classic model I give below:
EDIT: There is a writing error .. Rse is the parasitic resistance between sensor (NTC) and environment .. and Rxe is the one between object (wirst) and environment
The pattern is correct right? Is there anything missing?
How do I choose parameter values highlighted in yellow:
1) Rxs
2) Rse
3) Cs
4) Cx
I attach NTCs that I am using.
Alec_t
Joined Sep 17, 2013
15,160
Where is the heated fabric? Shouldn't its thermal capacity, temperature and thermal resistance(s) to the environment be modelled?
Are the wrist and 'the object' the same thing?
Are the NTC and the sensor the same thing?
Does 'the environment' include the heated object?
Why is the 'resistance between NTC and environment' represented twice, with different values?
By guestimation, unless you have some actual values for reference.
kalemaxon89
Joined Oct 12, 2022
389
How? Experimentally what measurements should I make? Do I give it power and count in how many seconds it comes back to room temperature?
Yes
Yes
I don't know ... for simplicity no (?)
You are right! There is a writing error :(
