The voltage in corrosion removal electrolysis?
DickCappels
Joined Aug 21, 2008
10,662
But.. keep the voltage low so nobody gets shocked. When I worked as an anodized I had to continuously adjust the voltage to keep the current in range, so if you can use an adjustable power supply and a current meter you are all set.
The higher the current the faster the corrosion is removed. How much current to use? Just keep things from getting very hot.
