It's almost two months since I suggest the very same thing:Hello,
The TS might also have a look at the books of Douglas Self:
https://archive.org/details/audio-power-amplifier-design-handbook-4th-ed./mode/2up
https://archive.org/details/self-on-audio-2nd-ed./mode/2up
Those will give a lot of details on how to design an audio amplifier.
If you can see distortion on an oscilloscope then there's far too much of it! I would suggest that the distortion needs to improve by at least three orders of magnitude before it is worth investing in an Audio Precision analyser!And another irritation.
TS is trying to measure distortion with an oscilloscope. You cannot measure distortion without expensive instruments.
I measure distortion by listening to the speaker output.
And I can go on and on...
Good in is also bad out for his amplifier.Hello,
Also what he will see on his oscilloscope will be dependend on the quality of the input signal.
Bad in is bad out.
Bridged outputs create 3.5 times more power than a single ordinary amplifier when using his fairly low voltage (7.2V) rechargeable battery. Almost all ordinary car amplifiers are bridged for that reason. His single amplifier has a maximum output (almost clipping) of 6Vp-p when powered from 7.2V which is only 0.56W into 8 ohms per channel. When bridged and adjusted for symmetrical clipping on both sides, the output is about 2W. He was also thinking about using two batteries for 14.4V plus bridging to almost get "car-radio" power, except car radios use 4 ohm speakers and his amplifier will need re-design to drive 4 ohm speakers with a 14.4V supply. Also, his little batteries will die sooner.Also TS should be aware that there are millions (or billions) of devices on the planet with audio amplifiers that do not use bridged outputs.
Fuse bridged with wire on cheap electrical goods ? | General Electronics Chat | 10 |
| Similar threads |
