the secondary phase voltage is ___ volts
dl324
Joined Mar 30, 2015
18,421
Oh just these two... I'm taking a test as we speak and the instructor never discussed this kind of stuff but, he put it on the test...
If this is for school work, you should post in Homework Help. You'll learn more because we won't just feed you answers.
27,777
Yes, that is indeed cheating unless it is a test of seeing if you can locate answers. But the really stupid part of believing that there is no reason to know if you can research is that first, a time will come when looking up is not possible, and second, looking up does not usually lead to understanding and insight, which are how people can be different from stones and dirt. Learning is FAR MORE than just collecting facts, which you may have time to research if you are really lucky. Learning is about gaining understanding, and that is not possible by looking it up on the internet.
In the case of the first transformer, believing that you are only dealing with 240 volts when actually it is 7200 would probably be fatal, which ends all chances of looking it up.
