The seawater cell...
Externet
Joined Nov 29, 2005
2,668
Nothing extraordinary, nor new. Uses zinc and graphite in saltwater.
1.- How is the voltage generated determined/predicted ?
Is it by looking at a galvanic table like ----> http://l-36.com/corrosion.php
Where graphite is +0.25 V and zinc is -1V; yielding as answer a differential of 1.25V ,
Or, should this electrochemical series table be the one to look up ? ----> http://www.chemistry-assignment.com/wp-content/uploads/2013/02/1189.png
And why is carbon not listed there, to attempt reading a differential ?
or is there another method ?
2.- To turn white LEDs on; there has to be a circuit to convert the voltage to near 4V, am I right ?
It is commonly available as ----> https://duckduckgo.com/?q=salt+water+lamp&t=canonical&iax=1&ia=images
3.- Does this mean that using aluminium and stainless steel would yield about the same voltage ?
----> http://xapps.xyleminc.com/Crest.Grindex/help/grindex/contents/corrosionMetal4_files/c03_2.jpg
Externet
Joined Nov 29, 2005
2,668
Thanks. The book is not viewable. The attachment does not address 1, 2, 3.
With your knowledge, explaining these doubts should be quick and simple.
