The Jokes thread
dacflyer
Joined Nov 19, 2010
31
those were Awesome...
Airline Maintenance
After every flight, Qantas pilots fill out a form, called a “gripe sheet,” which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form, and then pilots review the gripe sheets before the next flight. Never let it be said that ground crews lack a sense of humor.
Here are some actual maintenance complaints submitted by Qantas’ pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers. By the way, Qantas is the only major airline that has never had an accident.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget.
wayneh
Joined Sep 9, 2010
18,127
3 and 4 are dark. 3 is dark because D3 bypasses it. 4 is dark because there is no way to get the anode voltage above the cathode voltage.
cmartinez
Joined Jan 17, 2007
8,796
I agree with the first part, but wouldn't a circuit be formed through R1, LED4 and D2, lighting up LED4? Voltage drop would be less than the 6.3V from the power supply.
cmartinez
Joined Jan 17, 2007
8,796
And now for a bit of dark humor:
  • First act: Tony the Tiger is found murdered and skinned in the middle of the jungle.
  • Second act: Count Chocula lies in his castle inside his coffin, a wooden stake thrust through his heart.
  • Third act: Yellow police tape is blocking the door to Snap, Crackle and Pop's apartment. Their stabbed bodies lay lifeless in their bedroom.
What is the name of the play?
"Cereal killer" ...
killivolt Off-Topic 10
KL7AJ Off-Topic 1
Sparky49 Feedback and Suggestions 4
electronis whiz Off-Topic 2
electronis whiz Off-Topic 1
