The IXD630 question
Janis59
Joined Aug 21, 2017
1,893
Hey, hey!
Probably some of You may explain the gate driver IXD630 (https://www.ixysic.com/home/pdfs.nsf/www/IXD_630.pdf/$file/IXD_630.pdf) appropriatness to one of my projects have to applicate it to 3 MHz meander power booster based on DE375.
In the datasheet is said the 20 nsec the risetime and falltime, and 65 nsec for on-off delaytime and the same for off-on delaytime.
Even to take the dalay in (what rather more probable may be omitted for regular oscillation) then 20+20+65+65=170 nsec or 5.88 MHz however in that datasheet all the frequency-bound graphs are ending with 1 MHz and nothing above. May I read it between the raws that 1...6 MHz range is kind of forbidden area? Or what wrong will happen applying it to 3 MHz??
LowQCab
Joined Nov 6, 2012
5,102
Everything that can possibly go wrong, will go wrong, up in the Megahertz region.
Have You successfully created any projects that operate in the Megahertz region ?
