The common-collector amplifier - CORRECTION
Wendy
Joined Mar 24, 2008
23,801
Where are you talking about, this paragraph?
Here's another view of the circuit (Figure below) with oscilloscopes connected to several points of interest.
Common collector non-inverting voltage gain is 1.
Since this amplifier configuration doesn't provide any voltage gain (in fact, in practice it actually has a voltage gain of slightly less than 1), its only amplifying factor is current. The common-emitter amplifier configuration examined in the previous section had a current gain equal to the β of the transistor, being that the input current went through the base and the output (load) current went through the collector, and β by definition is the ratio between the collector and base currents. In the common-collector configuration, though, the load is situated in series with the emitter, and thus its current is equal to the emitter current. With the emitter carrying collector current and base current, the load in this type of amplifier has all the current of the collector running through it plus the input current of the base. This yields a current gain of β plus 1:
mrchen
Joined Oct 6, 2013
7
No, not this one. Just search the page for the quoted phrase.
But, incidentally, the picture with the oscilloscopes is bad as well. The (black) negative lead of an oscilloscope is connected the ground/earth. By connecting the scopes as in the picture you would SHORT the left hand ( base bias ) battery. See this video for details:
http://www.youtube.com/watch?v=xaELqAo4kkQ
33,027
That's actually a touchy (not the right term, but I don't have a better one handy) point. Arguably the point of those scopes is just to illustrate a concept and, as such, they are not real scopes with the common limitations of real scopes. Plus, not all real scopes have single-ended inputs (but most do and the ones that don't are quite expensive and quite proud about it).
Also, the "scopes" that are used in the GUI interfaces for simulation software are never (that I am aware of) single-ended, which is reasonable given what their purpose is.
Having said all that, it's a point that needs to be made (repeatedly) because people routinely have no idea that not only are the grounds of their actual scope probes tied together (they tend to think of them as if they were like multiple voltmeters), but that they are typically tied to the chassis ground and hence to the ground wire of the AC supply cable. As a consequence, they interact with any other equipment that is mains powered. Thus, in most circumstances, you should let your oscilloscope probes define you one ground point of the circuit.
mrchen
Joined Oct 6, 2013
7
Applying a common-collector configuration I never would connect the input signal between base and emitter (by the way: "between" is more accurat than simply "and"). Rather, it is applied between base and ground!
The phrase "Common collector: Input is applied to base and collector" in the original article was an attempt to explain the term "Common collector". The expression "between base and ground" is more accurate indeed but it does not explain the term "Common collector".
BTW, when you quote a message and edit that quote, it's good style to make it clear that the quote was modified. Otherwise the readers might be misled.
mrchen
Joined Oct 6, 2013
7
The scope probe feature of the immensely popular simulator LTSpice uses the circuit ground as reference, which is a general safe practice with oscilloscopes.
LvW
Joined Jun 13, 2013
2,032
mrchen, was there a misunderstanding?
I took the quote from the second part of your post - and your suggestion was "...between base and EMITTER" .
Do you still recommend this change?
(By the way, the only quote editing was an underlining, nothing else)
mrchen
Joined Oct 6, 2013
7
I can only recommend removing the incorrect phrase. The article needs to provide a good explaination for the term "common collector". Unfortunately I cannot offer a good explanation. Hopefully someone else will.
I don't see it that way. Just compare the OP and the quote. But let's move on, it's not paramount.
33,027
If you look at the small-signal equivalent circuit, the collector is tied to common. Hence, common-collector. This is often described as "signal ground" or "AC ground".
LvW
Joined Jun 13, 2013
2,032
OK - I follow your advice: Here comes again the quote from your first posting:
(Start of quote)
Correct phrase:
Common collector: Input is applied to base and EMITTER. Output is from emitter-collector circuit.
(End of quote).
Do you see any difference to the quote I have given in my post #5 ?
LvW
Joined Jun 13, 2013
2,032
But you have offered, indeed, something which you call a "correct phrase"!
And for my opinion it was not a "correct" phrase because the signal is to be applied between base and ground. And - as stated recently by WBahn - the collector is ac-wise connected to signal ground.
mrchen
Joined Oct 6, 2013
7
This is an interesting angle, please can you elaborate with a novice audience in mind so your explanation can be incorporated into the article.
33,027
Oh, I don't think there's too much interest in incorporating my explanations into the E-book. My explanations on most things come from a significantly different perspective than the one they are trying to promote. Not saying better or worse, but different.
