the circuit photo blur
xljin2014
Joined Nov 11, 2014
120
So what is your question about the circuit?
Ron
hi ,ron
my question is about shortly after the beginning of adding vcc, how it comes one transistor go saturation, and the other one go cut-off(right word?).
here is how I think: as vcc is added,
both transistor start to open by base resistance, but the transistors, base resistances,and collectors between are not the same exactly, so the two collector voltage are not the same.
assume left transistor's(v1) collector voltage go down faster, by coupleing of the left capacitor(c1),the voltage of the base of right transistor (v2) goes low, so v2 starts to cut off. the collector voltage stars to go up. and this voltage is coupled to v1's base, which make v1 goes to saturation.
I have two questions:
1. as I analysed before, the posative feedback happened to v1, we can also analyse v2 the same way. the difference is which one is quicker. my question is: what makes transistor go saturation or cut off. the collector goes quicker is the key?and why?
2.in this circuit, is collector voltage make sense or the voltage change make sense?I think is the second,because capacitor coupleing voltage change ,not voltage.
Delta Prime
Joined Nov 15, 2019
1,311
"hi, delta
i guess the osilation circuit you recommended is different with mine"
On the contrary!
The component values may be different, the 330Ω resistors and the LEDs are positioned differently. The function is identical.
If you take the time and read the entire thread as I suggested
It will answer every single one of your questions.
Although it is not as personal as I am talking to you right now .I will only be repeating what has already been stated.With that said... if you have any other questions please feel free to ask. And the schematic in the other thread wiggles. :cool:
xljin2014
Joined Nov 11, 2014
120
the circuit photo uploaded is blur. is it because of low resolution?where can I make resolution higher?
Mod: Adjusted the image.
how mod adjusted the image?
"hi, delta
On the contrary!
this is the circuit you give me , maybe wrong link.
AnalogKid
Joined Aug 1, 2013
12,222
Your base resistor values are way too low
No, they are not.
I increased them 10 times and reduced the capacitor values 10 times so that the timing is the same.
Now the base resistors are way too large. Assuming the Vf of the LEDs is approx 2.0 V, the ratio of collector current to base current is now 80:1. I'm not a huge fan of the 10:1 rule, but 80:1 is way too high, even for me. With the original resistor value it was 7.4:1. I suggest you increase the base resistors to 10 K and decrease the capacitors to 100 uF. The net change in frequency is 3%.
ak
