Alright, let’s do something boring: Building a battery charger. So why would you do that? I don’t have any idea, just go buy one! ;-) But apparently I had a reason to build one myself.
Some time ago I built a couple of rechargeable button-cell-battery-packs which are featured in one of my blog post (see website url in my profile).
After trying to recharge one of them with an old NiCd fast-charger I learned the hard way how my batteries actually look from the inside:
Don’t try this at home kids!
So far so good, I didn’t burn my flat yet, so I decided to either buy or build a charger that is designed to charge Nickel-Metal Hybride (NiMH) batteries with very little capacity.
What you always wanted to know about rechargeable batteries
First off, my tiny button cell accumulators have the following specs:
So why did my test-candidate explode then?
It was simply overcharged. NiMH cells are designed to be only fast-charged until they reach their full capacity. After that, keeping them connected to high current results in a lot of heat and…you saw the pics.
So either the charger has thermal sensors to shut off before overheating, or it just uses a low current the cell can withstand for a longer (infinite) time duration.
Sensoring seemed tedious so I decided to build a low current charger.
A safe current for NiMH cells is 1/10 of their capacity (1/10 C) or even less. In my batteries case this would be 1/10 * 80 = 8mA. There you have it: No affordable charger on the market seems to handle such a low current. Typically chargers go as low as 150 mA, which is fine for typical batteries which have a capacity of 1500 mAh to 2500 mAh (or even more), but not for my tiny 80 mAh cells.
Finding and customizing a circuit design
Some googling and studying charger designs brought up this forum thread. The schematic suggested by member SgtWookie seemed to be a perfect fit:
It features two regulator ICs (TLV1117C): One limiting the current (U1) and the other one the voltage (U2). The battery(pack) is represented by capacitor C2 (he uses the similar-to-battery-behaviour of the capacitor for the software simulation). I substituted the two regulators with the more common and easy to get LM317 type.
This is my final customized version. The 120k resistor R1 configures LM317_1 to limit charging current to 6mA, being even more healthy for my batteries than the discussed 8mA:
Some theory for the geeks
Skip this if it’s boring ;-) I’ll try to explain why in my case R2 surely is not necessary.
R1 power consumption - Original design
Assuming R2 is missing:
The formula for calculating the power consumption of a device (eg. a resistor) is
P = V * I
The V on R1 is unknown so just calculate it using Ohm’s law:
V = R * I = 10 Ohm * 260 mA = 10 * 0,26 = 2,6 V
Now find out how much power R1 has to withstand:
P = V * I = 2,6 * 0,26 = 0,676 W (Watts)
The most common resistors support max power levels of 0,3 to 0,5 Watts. With splitting the current in half by using a second resistor R2 in parallel with R1, also the power consumption is halfed to 0,338 W for each R.
R1 power consumption - Customized design
V = R * I = 120 Ohm * 6 mA = 120 * 0,006 = 0,72 V
P = V * I = 0,72 * 0,006 = 0,00432 W = 4,3 mW
4,3 milliwatts is almost nothing and every resistor form factor I know of would withstand it. No need for splitting the current in half with a second R.
How long does it take to load then?
theoretically:
t = C / I = 80mAh / 6mA = 0,080 / 0,006 = 13,33 h
I -> current in A
C -> capacity in Ah
t -> time in h
typically a loss of 30-40% has to be counted in, lets calc with 40%:
C = 0,080 + 40% = 0,080 * 1,4 = 0,112 t = C / A = 0,112 / 0,006 = 18,66 h
So let’s say a night and something. It should be safe to leave the charger connected for a couple of days.
Giving it a home
…and why it’s got its name.
That's the idea: A piece of perfboard inside a tape box, connectors for supply and battery-pack
Fun fact: An almost perfectly fitting battery-pack-holder comes for free!
An old 12V wall wart power supply should drive the thing.
Adjusting charging voltage to 2.9 Volts with the trim-pot. Notice the little jumper which is closed at the moment and will be used in the next pic.
Jumper is opened, which breaks the circuit and an amperemeter can be put into the circuit to measure the charging current
I used 2 IC sockets so resistor R1 can be easily exchanged to adjust charging current - A 120 Ohms R adjusts the regulator to roughly 6 mA
Another neat feature: 2 IC sockets to easily plug in stuff that doesn't have the special 4-pin-connector. Certainly regular AA batteries could be charged as well. For this use-case charging current could be increased by exchanging R1 with a lower value.
Materials
LM317 regulator
Those are for building power and battery connector plugs:
10 pin strip (for 4-pin battery connector and 5-pin power supply connector
Unfortunately musikding.de doesn’t have the female ones in stock.
Take these 20 pin inline sockets for the resistor connector and the additional regular-battery-holder connector. They are also called transistor-sockets. Keep in mind that they have small holes. Above pin strips won’t fit together with them!
On Amazon you can find combination packs with headers and sockets that fit together, eg:
30 Pcs 40 Pin 2.54mm Male and Female Pin Headers
For resistors buy anything, anywhere. I like Metal Film types, they are quite cheap but can stand about 0,6 Watts, which is a little more than the most common ones with 0,25 Watts (I think they are called carbon-layer). You won’t need higher power resistors for this project but it’s good to have some in the stash.
The power supply can be almost anything you have lying around. It should deliver a minimum of 6V, I think the LM317 needs this, maybe it works with a 5V one. The absolute maximum input voltage for this IC is up to 30V, so you have a wide range of choices between these values.
If you interested in music-related electronics and coding head over to my blog website and find more interesting stuff. Link is in my AAC profile.
- 1,2 V (exactely the same as normal AA, AAA, etc. rechargable batteries; this value is nominal, in reality most of them have a little more, something like 1,3 to 1,45 when fully charged)
- 80 mAh (milliampere hours) capacity
- Charging voltage should be set slightly higher than the voltage of the fully charged battery pack. My two-cell packs have about 2 * 1,35 = 2,7 V so around 2,8-2,9 V should be fine.
- Fortunately the design already handles charging voltage for two-cell packs. It can be fine tuned using the trim-pot R5.
- measure between point A and ground
- Charging current as discussed above, not more than 8 mA.
- It is set by resistors R1,R2 (On first sight it is slightly confusing that he uses 2 identical resistors in parallel. I suppose he did this to split the current (and thus the power consumption) in half and spare the use of an R with higher power specs (more Watts - more expensive - not as common in ones components stash), I will use just one R as my current is very little compared to the 260 mA in the original design. Let’s just call my resistor R1 and forget about R2.).
- open circuit between points A and B and connect multimeter in between for measuring
P = V * I
theoretically:
I -> current in A
C -> capacity in Ah
t -> time in h
Giving it a home
Another neat feature: 2 IC sockets to easily plug in stuff that doesn't have the special 4-pin-connector. Certainly regular AA batteries could be charged as well. For this use-case charging current could be increased by exchanging R1 with a lower value.Materials
LM317 regulator
