testing load cell
dashhossein
Joined Jul 30, 2020
49
hello ,
i have a 40 KG load cell which i doubt that it is work correctly ,
for test i connected the black wire to negative and red wire that to +5 V electricity then connect white and green wires to multy meter .
multymeter switched to millivolt DC , it show -1 V and if i pressure to load cell nothing will change .
also resistance between red and black is 286 Ohm , and the resistance of green and white is 286 Ohm too .
is something went wrong ?
should i replace the load cell ?
ericgibbs
Joined Jan 29, 2010
21,651
hi,
If your are confident that the resistance measurements are correct and the fact it will not register a weight as an output mVoltage, indicates the LC is defective,
E
dashhossein
Joined Jul 30, 2020
49
hi,
E
is it important to connect LC to 10 V ? i use 5 V
last question is it possible to check health of LC only from resistance between elements ? if yes how should we calculate ?
