I just want to verify that each of the LEDs is working for each color. I want to do that by powering the entire LED strip so that all the REDs come on, then test all the BLUE and then all the Green.
One video on YouTube shows the person in the video connecting the positive power source directly to the marked 12v pin on the Led strip then touching the Negative lead to the 'R', 'G' and 'B' pins one by one to light them.
Another video says you have to use resistors and transistors.
Usually, I just use a 220 ohm resistor with LEDs and other wise apply the related power directly. Is there a reason I can't do that with an RGB LED strip containing multiple LED's ?
