Testing a 2N3819 JFET, alternative JFETs?
hrs
Joined Jun 13, 2014
539
Is this a correct way to test a 2N3819?
In an LTSpice simulation the resistor drops all the voltage as I would expect. On the breadboard all of the supply voltage is across the transistor. I tried multiple parts. Have I been duped?
I bought this a long time ago when I still thought Ebay etc would be good enough for hobby use. This was bought from Utsource. They have their own stock and they do drop shipping. This part comes from drop shipping.
What comparable JFET would you buy today? SOT23 would be ok if it avoids this TO-92 NOS fakery. Or I did it wrong of course and the part is fine ...
38,882
You should get at least 2mA through the transistor in your circuit.
Are you sure you have the transistor is connected exactly as shown in the schematic?
Double-check the transistor pinout for the package you have.
hrs
Joined Jun 13, 2014
539
It is the way to check the Idss
Yes, and 0V over the resistor would imply no current I think?
Perhaps you mean 0.2 mA, 6V/22k = 0.27 mA?
:eek:I was using the OnSemi datasheet. The device is marked Fairchild. The Fairchild datasheet has source and drain swapped. Perhaps I destroyed the device* so I took a new one, used it according the Fairchild datasheet and changed R to 2k for ~2 mA. The result is the same. I've attached a picture of the breadboard.
*Though I have read that for some of these small signal JFETs it is ok to swap source and drain.
bertus
Joined Apr 5, 2008
23,014
The 22k ressitor is to large.
Try a 1k resistor and retest.
Also check the pinout:
When there is no voltage accross the resistor, it could also be a bad contact in the breadboard.
Bertus
hrs
Joined Jun 13, 2014
539
After putting in 1k things are as before, not working. I also put my DMM in circuit measuring 0.0 uA from PSU to drain.
hrs
Joined Jun 13, 2014
539
I thought of looking in a stash of components graciously given to me by someone no longer interested in electronics. Lots of old stuff. I found some 2N3819s and a K49 (2SK49?). Both appear to behave like JFETs in the above test circuit (1k resistor) but both drop around 0.7 V between drain and source. This drop increases with supply voltage. I missed this at first, but so does the simulation.
Alec_t wrote somewhere on this forum that a 2N3819 is in fact a BJT (head asplodes). Does the BJTness of this JFET cause it to drop voltage?
hrs
Joined Jun 13, 2014
539
Why would you think there would be no voltage drop?
You are seeing the channel resistance of the FET when it is fully on (below).
I don't know. I thought it would be "super low" like with MOSFETs. The datasheets I looked at don't mention rDS(on). They mention admittance, conductance and susceptance in mmhos. Then my eyes glazed over and I continued the experiment.
Alec_t
Joined Sep 17, 2013
15,158
I don't remember doing that, but have checked and indeed I did. We don't normally think of it as a bjt, but its internal structure has both n-type and p-type silicon, with a junction between gate and source/drain.
hrs
Joined Jun 13, 2014
539
Hi Alec,
I was referring to this post:
https://forum.allaboutcircuits.com/...t-on-peak-atlas-analyser.133788/#post-1113775
But in the context of that thread it's different, like you say. Now that I have a good JFET I can measure around 0.9V between GS and GD.
BobTPH
Joined Jun 5, 2013
11,664
Unless I am missing something , your breadboard picture shows no connection to pin 1 of your jfet, and no connection to one of the pins of the resistor.
Can someone else please check out the picture?
Bob
sparky 1
Joined Nov 3, 2018
1,218
The article is formatted with an arrow go to the next page at the bottom page.
https://www.allaboutcircuits.com/te...hpt-5/junction-field-effect-transistors-jfet/
in contrast is an article that is gives detailed examples
https://www.nutsvolts.com/magazine/article/fet_principles_and_circuits_part_2
hrs asked about an old report
https://forum.allaboutcircuits.com/...s-shown-as-bjt-on-peak-atlas-analyser.133788/
No that is not true of a real 2N3819 reads n-jfet which means n-channel junction field effect transistor. Test fine without any problem.
In circuit it acts like a jfet and not at all like an NPN. That report is misleading. At first transistors seem to not work.
Keep trying with an NPN
38,882
Yes it may have n and p type silicon but its structure is significantly different than a BJT, so normally or abnormally, it should not be thought of as a BJT.
