Temperature measurement
Konstabel
Joined Jan 31, 2008
52
I need to measure the temperature of a tub of water. What would be the best/easiest way to do this. Thermocouple or thermistor circuit? I would like to be able to dunk the sensor in the water.
beenthere
Joined Apr 20, 2004
15,819
If you use a LM34 or 35, you get an output that is already scaled in engineering units. What is going to be reading/displaying the temperature?
SgtWookie
Joined Jul 17, 2007
22,230
The LM34 gives output in Farenheit, the LM35 in Centigrade.
There are other options, as well:
LM134/234/334 - adjustable current source & temp sensor
LM135/235/335 - precision temp sensor in °K
LM56 - dual thermostat; in case you want to have fixed triggers at certain temps.
Wendy
Joined Mar 24, 2008
23,810
Dip it or wrap it in plastic would do it, you can get insulative dips pretty inexpensively at the hardware store, think rubber based coating.
