temperature coefficient of VCA
pgo1
Joined Nov 7, 2012
67
the v2164 VCA has a gain coefficient of -3300 ppm/C. I'm not 100% sure how to use this figure. If i put a control voltage of -660mV (20dB) and an input voltage of 1 volt, how do i calculate the difference in gain per degree celsius?
joeyd999
Joined Jun 6, 2011
6,279
The datasheet says there is a gain constant of -33mV/dB. The next line says the (typical) Gain Constant Temperature Coefficient is -3300 ppm/°C.
Therefore, for each 1°C rise in temperature, you can expect about a -3,300/1,000,000 change in the constant.
Note that this is typical! They don't give a min or max -- so use with caution.
joeyd999
Joined Jun 6, 2011
6,279
They also supply a handy graph!
Though, I have no idea why they show +/- values on the temperature axis. I've never seen that before.
