Telephone timer with auto disconnect..?
GaryButcher
Joined Apr 23, 2017
Here in the UK many service providers offer unlimited minutes for landline usage, but subject to a maximum call time of 60 minutes. My wife regularly overruns this when chatting to her best friend so I'd like some ideas on a timer circuit which will (ideally) disconnect the call after 60 seconds or, failing that, put a beep on the line so that she knows to hang up and re-dial. I've built a few circuits in the past but am still very much a newbie so unfortunately more abstract advice like "you need to build a self-oscillating feedback circuit" won't be of much use to me :) If anybody has built such a telephone timer circuit and would be willing to share, that would be ideal. As a side note, there is a ready built circuit board available fairly cheaply here in the UK but the timer only goes up to 20 minutes, so in principle I guess it is possible!
Many thanks,
Gary
Reloadron
Joined Jan 15, 2015
7,908
I would imagine a simple digital count down timer could be set beside the telephone. At call start start the timer and get done before the timer has counted down an hour of elapsed time. This way it would not be invasive to the phone line.
Ron
GaryButcher
Joined Apr 23, 2017
Hi Ron, thanks for your reply. Yes that had occurred to me, however I was ideally looking for something that didn't require you to set a timer manually.
Regards
Gary
In the US, the proper way would be to use a DAA. See http://www.cermetek.com/catalog/telephone-line-interface/ I have no idea about UK requirements.
The PICAXE processor might be easy to use. www.picaxe.com
Your idea would nor be limited to one phone either. e.g.
Monitor the off hook time and inject a tone periodically starting at 58 minutes and auto-hangup at 59 minutes.
For incoming calls, you could say, make it beep 2x only and not hang up.
DickCappels
Joined Aug 21, 2008
10,662
How about an electromechanical solutiom to the prohibition against connecting to the phone lines! Use a mechanical switch (or optical if you like) to detect when the handset is off the cradle.
AlbertHall
Joined Jun 4, 2014
12,640
And then a solenoid could press the cradle to disconnect the call after a suitable warning time.
GaryButcher
Joined Apr 23, 2017
Many thanks for all the replies. It seems that this isn't as straightforward as I initially thought so for now I'll just continue nagging her every time the phone bill comes in and maybe think about the more low tech solutions that have been suggested.
