What do you think about it @JoeJester, seems like an ok intstrument?
OK .....
First off,
TP502 + TO Q508 E should be zero
TP502 + to Q510 E should be 0.44 however, IF you used those mini-clips .... 1.5 is possible. as you already reported a 1 ohm error. Since this is a no power applied test, just use the probes.
TP502 - TO Q508 E should be 0.44
TP502 - TO Q510 E should be zero.
That's good for one set of transistors. Q509 E and Q 510 E emitter resistors would need to be tested as well. Use the probes that came with the DMM. Check the zero by shorting them and note the reading.
TP501 + to Qxxx E tests the following:
Q509 E ... Tests the connection between the + and the emitter
Q510 E ... Tests R548 and R550
Q516 E ... Tests R548 and R570
Q518 E ... Tests R548 and R572
Each resistor is 0.22 +/- 2% Your meter is has a tolerance and a plus digits count. The resistors alone can be 0.216 - 0.224 so two of them would be double that.
Do the tests over, as I described to the four emitters. Report your results.
Maybe TP501 has wrong print at the pcb also?
okey!Sorry, I made a mistake when I said TP501 .... as we are working with TP502, the right channel.
TP502 + to Qxxx E tests the following:
Q508 E ... Tests the connection between the + and the emitter
TP502- to Qxxx E tests the following
Q508 E ... tests R550 and R548
Q510 E ... tests the connection between the - and the emitter
Q516 E ... tests R550 and R570
Q518 E ... tests R550 and R572
Other that the direct connections (zero ohms), all others should read 0.44 ohms
If there are any problems we can check the left channel prior to ordering any parts.
I get open circuit at 200 Ohm setting ( 0L. )What is the reading between TP502 + and TP502 - ?
Because i used the mini grabbers with 1.3 ohm error. Might have increased when connected to the pinsDon't jump to any conclusions too quickly.
Your readings do not match what you had previously measured and reported in post #508.
Okey, so i will measure TP501(?) not TP502? To what resistors?Damn, I don't like it but it does appear the emitter resistors to Q508 and Q516 are open.
With that being said, Measure TP501 to it's associated resistors in the same manner ...... to see if other emitter resistors are open before ordering any.
For further confirmation you will have to measure the resistors individually. Make a list of resistors and measure them individually. One of the resistors on the 0.6 reading is probably exceeding the 0.22 if not both of them.
I hope you used only the probes for that test.
They showed 0.2 at first, then stabilized at 0.3Ok....as surmized from your major test, we identified two open resistors.
Now R550 and R572 measured 0.300 on your meter or did you round it up?
| Thread starter | Similar threads | Forum | Replies | Date |
Technics VX800 Extended Drive No Sound?? | Technical Repair | 30 | |
Technics SU-VX800 amplifier parts availability | Technical Repair | 3 | |
| M | Technics current drive problem on a vx800 | General Electronics Chat | 6 | |
| B | Technics SU VX800 Amp Problem | General Electronics Chat | 4 | |
Technics SU-VX800 Repair Help | General Electronics Chat | 13 |
