Lestraveled
- Joined May 19, 2014
- 1,946
OK, your speaker/cabinet is marginal for a low level bass guitar practice amp. So, I think your distortion is coming from your amplifier. How is your power supply fix coming?
Mark
Mark
I would say it's a bit better with both +12V and -12V levels being powerful enough. Still, there is some distortion present when the circuit I use as a preamp is turned almost all way down, and if I turn it up a bit it sounds like I have a fuzz box cranked up to it's max instead.OK, your speaker/cabinet is marginal for a low level bass guitar practice amp. So, I think your distortion is coming from your amplifier. How is your power supply fix coming?
Mark
I am afraid I can't find an o'scope any time soon....I think it's time to beg or borrow an audio sine generator and a 'scope to see the waveforms.
Without those it is a lot of "guessing in the dark" and that's a lousy way to try to fix things.
That is probably a result of the amp input stage being over-driven.and if I turn it up a bit it sounds like I have a fuzz box cranked up to it's max instead.
Can higher supply voltages (>=15V) help?That is probably a result of the amp input stage being over-driven.
Little "DSOnano" 'scopes can be bought brand new all over Ebay for about $73;...
And even a 12" driver is considered less than optimal, most bass players will go for a 15" driver. Especially in heavy rock with 5 string Bass guitar (low B string).
That's a very strong (and LOUD) opinion!STOP!!!
Do NOT NOT NOT buy any of those so called pocket scopes!!! They are merely kids toys and are TOTALLY USELESS!!!
My 12" is better than your 15". It's not the size but the quality that counts.
It's the driver behind it that matters.
by Aaron Carman
by Jake Hertz
by Duane Benson
by Duane Benson
