Taking a Drawing and Creating a PCB Gerber File
SLK001
Joined Nov 29, 2011
1,549
What is this design supposed to do?
Have you breadboarded this to your satisfaction?
How soon do you need Gerbers?
What is your budget for this?
sydcomebak
Joined Dec 13, 2011
69
Lestraveled
Joined May 19, 2014
1,946
Do you have a printer? If you do, why don't you download ExpressPCB, free and easy to learn, and design your own PCB? You could make your own PCBs in your kitchen.
sydcomebak
Joined Dec 13, 2011
69
This would hopefully be mass produced soon, so hand drawing or home printing a pcb was a step I thought I could skip using a VERO board (done). The mass-production ppl need a Gerber file to get me my sample 25 boards for $250 (no idea if that is too steep)
Lestraveled
Joined May 19, 2014
1,946
You seem intelligent. I bet it would only take you about 4 hours before you had your first cut. You can take a screen shop and post it here and I am sure you would get a lot of help. (A lot of us here make our own PCBs.) ExpressPCB allows you to print the image, which will allow you to make transparencies for making your PCB, or you could have ExpressPCB make the boards for you. They deliver very fast and will give you a quote instantly on your computer. I would use them just for the first few boards, call them production prototypes, before you dump out a lot of money for a big lot of them. It is very wise to take small steps especially when you are inexperienced.
sydcomebak
Joined Dec 13, 2011
69
It was suggested in another thread to try out Eagle to design and lay out the PCB. I may pull an all-nighter with YouTube and some scotch.
ebeowulf17
Joined Aug 12, 2014
3,307
This is strictly personal opinion, but I taught myself some basic pcb layout work pretty recently and tried lots of free software along the way.
Personally, I found KiCad very difficult and counter intuitive to learn and eventually gave up. I did my first project in Eagle with good results. The interface is a little clunky and awkward, but it wasn't too hard to learn and it did a great job. Only big complaint is how difficult it is to design your own parts/footprints. Then I found DipTrace, and I absolutely loved it. I've used it for several projects now - can't say the results are any different than in Eagle, but the workflow and learning curve are much nicer (at least for my mindset) and there are lots of nice extras, like the way related parts and traces are highlighted when you hover over any part or trace - little details that make it a lot easier to check your work, track down errors, etc.
I never did try ExpressPCB, but I've heard plenty of good things there too.
Anyway, the point I was trying to make in all my rambling is that KiCad can be really hard to get started with, and several alternatives are much easier. Don't get discouraged - teach yourself Eagle, DipTrace, or ExpressPCB, and you probably can make a reasonable first attempt at this fairly quickly. When it feels close, share what you've got and we'll provide feedback.
P.S. The scotch sounds like a good plan too!
ebeowulf17
Joined Aug 12, 2014
3,307
See and this is exactly what I didn't need... :(
Now I have to question which one to even try to learn... Gah!
Ooh, sorry. Forget I said anything and just trust Lestraveled on this one.
He's probably right and besides, if you decide at some point in the future to try a different program, there's no harm in having learned this one first. It's not a long term commitment to pick one tonight. Just go for it, have fun, and get your first prototype rolling!
sydcomebak
Joined Dec 13, 2011
69
So far, OK progress:
But I feel like all my settings are out of wack. These lines seem too wide...
I also have no clue yet how to put the battery holder and switch on the bottom side to connect to the thru-holes.
jpanhalt
Joined Jan 18, 2008
11,087
At first glance, R5 is not connected. What program are you using? I agree with nerdgutta, if you want to make progress, upload your schematic. Also, since there is high probability it will have to be imported and re-drawn in a program that provides schematic capture, give some dimensions for that PCB that you want.
John
djsfantasi
Joined Apr 11, 2010
9,237
@jpanhalt Why is schematic capture important?
TS - @sydcomebak - what PCB program did you use? ExpressPCB has a page of recommended practices which you should read. The others likely have a similar resource as well.
I too urge you to upload your PCB file.
sydcomebak
Joined Dec 13, 2011
69
Some of the connections are not done. I was falling asleep at the keyboard and took a screenshot of my progress so far. The only part I got done was the 555 Route from pin 3 to 5.
jpanhalt
Joined Jan 18, 2008
11,087
Can you simply post a schematic of what you are trying to route? It would be a cinch to show you an early version of the board with airwires displayed. I suspect once you see that, you will never want to route a board without using it. I am assuming that the only critical placement for parts are the LED's. Right?
John
