Switching 12V via mosfet taking signal from external device RGB led
AlexJJ
Joined Oct 8, 2024
I have device with RGB led which have 4 working states: Red, Green, Blue and Red+Green, my goal is to switch external 12V depending on RGB led states.
I draw this:
It will work or I made mistake somewhere?
Thank you for any advice.
sghioto
Joined Dec 31, 2017
8,756
Looks like a lot of mistakes from what I can figure, from what you are trying to accomplish I think.
So there are four states, which states are suppose to switch 12 volts and is it a High or Low side switching?
AlexJJ
Joined Oct 8, 2024
There is only high switching.
Blue high -> 12V blue on
Red+green high -> 12V r+g on
Red -> 12V Red on
Green -> 12V Green on
Blue is simple, r+g its AND gate so also.
Red and Green is more complicated that's why I use PNP to off this gates when certain or both transistor are on.
sghioto
Joined Dec 31, 2017
8,756
How are Q2,Q3 and Q4 supposed to be activated through U4? Does U4 represent simple diodes?
What is this RGB LED device exactly?
Are you trying to get a 12 volt output when any color is activated on the RGB module or just certain colors?
AlexJJ
Joined Oct 8, 2024
Cos there is also AND R+G signal and if I do individual when R+G will high, I will have on 3 signals, not only one.
