The PSU negative rails on a synth I'm repairing are outputting double their specified values. The -15V rails (A and B) are outputting -27-28V, and the -5V rail is outputting -10V.
The positive rails are fine. Well, the +15V is outputting a little low @ 14.2V but still nothing like the negative rails. Also, the PSU is disconnected from the rest of the synth.
The synth is old and I had measured AC on the DC rails so decided to recap and replace a bunch of old components, including the rectifiers and all of the transistors. Many of the parts are obsolete so I replaced them with suitable substitutes. The substituted parts are as follows (originals on left, replacements on right):
Diodes
D1-D4: 1S2473 - 1N4148 x 4
_________________
Transistors
Q1-Q4: 2SD313E - BD243C x 4
Q5-Q7: 2SC536G - KSC1815YTA x 3
Q8-Q10: 2SB507E - KSA940TU x 3 (BD244C)
Q11-Q12: 2SA564R - BC557BTA x 2
Q13: 2SB560E - BC640 x 1
_________________
IC
IC1: UPC141C - UPC305C x 1
I replaced the caps with good quality like for likes.
It's a bit of a noodle scratcher. I have no idea why this would be happening, particularly on the negative rails only.
I initially replaced the B507E transistors with the KSA940TU, which should be a suitable replacement. Given that those transistors are all on the negative rail part of the circuit, I thought it might be something to do with them, so replaced them with BD244C, which are complementary transistors to the BD243C on the positive rail circuit. But the problem persists.
As I said, a noodle scratcher. Hope someone can help.
The schematics of the PSU are attached.
Diodes
_________________
Transistors
_________________
IC
