Hello, did you manage to repair it, I have a Roland rs-70 that is identical on board to the juno D, only with foppy and USB, this keyboard turns on the panel lights, and they flash, and the LCD does not show anything, I can't find the problem, Everything seems fine, and I am not very skilled in electronics, I already replaced all the MB capacitors, all the SMD capacitors of IC 18 and IC7, changed Q17, found Q19 bad and Q16, the same DBeam LED is burned out, and I don't know how to measure IC6 on the panel. I don't know if the keyboard sounds, can you help me with what you did with the keyboard at the end?
Mod: link to old thread. @Yami
https://forum.allaboutcircuits.com/...zer-gets-stuck-at-startup.163830/post-1501075
