Synth Not Starting Up
IWorkInPixels
Joined Sep 25, 2015
55
I recently attempted a build of the Notes and Volts NaV-1 synth (Board layout and schematic available at http://www.notesandvolts.com/2013/03/nav-1-arduino-synth-build-it.html) and I *think* the ATMEGA328PU that drives it is not wanting to start up.
Upon completion of the board, I triple-checked that all trace cuts were done in the appropriate locations and that my multimeter did not show continuity across them. I verified that all the ground points had continuity, then powered up the board without any chips in the sockets, and verified that all the places that should be getting 5v were getting 5v. I plugged all the chips in, powered the board back up, and found that I was unable to upload the firmware to the ATMEGA using the ISP headers, so I removed the chip and stuck it in the chassis of an UNO to upload the firmware, then popped it out and put it back in the synth mainboard. After that, I powered up the synth, and the LCD turns on, with two rows of boxes, but no splash screen, and there's a repetitive noise coming out of the audio out connection. So, I hooked up the oscilloscope, and probed the pins of both microcontrollers where signals should be coming out, but only got ~2mV noise.
Here's a video of it failing to start:
This is BY FAR the most complicated thing I've ever built, so I'm really beyond my skill level here... I don't know what to check next. I have triple checked that all the components, jumper wires, and trace cuts are correctly located, that the upload was successful to the ATMEGA chip... there is a pin that's slightly bent on the optocoupler, but as far as I can tell it's still working, and even if it wasn't it shouldn't affect the rest of the board.
How should I proceed in diagnosing this so I can get it fixed?
Thanks.
IWorkInPixels
Joined Sep 25, 2015
55
Ha ha! One step closer to victory... I found the tiniest bridge ever between two of the rows right by the ISP headers, scratched it out and now the board comes up, shows the Notes & Volts splash screen, formats the eeprom, and all the buttons work as expected.
But no sound comes out. That may be because of my keyboard, which I don't think I can put into omni mode. Either way, now my oscilloscope will be a much more useful tool in figuring out where the sound is getting stopped... I'm hoping I didn't fry the soundgin chip, because there's not too many of 'em left anywhere. bridge.jpg
IWorkInPixels
Joined Sep 25, 2015
55
Ok, so if I alter the firmware to output some test notes over and over it will do so dutifully, so the soundgin chip is still good. I also probed the sound output pin and got the correct carrier square wave, so we're in business there.
Then, I probed the output of the optocoupler, and pressed some keys on the MIDI keyboard, and sure enough, the MIDI commands show up too.
So, I altered the firmware to listen on channel 1 instead of OMNI and fired it back up... made sure my keyboard was on channel 1... and nothing. So I'm thinking that means the problem has to be in the firmware, and it for some reason isn't actually registering the note commands I'm sending it and forwarding them to the soundgin.
Alec_t
Joined Sep 17, 2013
15,121
If that image is supposed to be MIDI signals, shouldn't they all be logic levels? That could be the area where the problem lies.
ISB123
Joined May 21, 2014
1,236
You should take a hobby knife and run it between the traces when using stripboard to check for any kind of bridges solves a lot of problems.
IWorkInPixels
Joined Sep 25, 2015
55
@Alec_t : I probed pins 4 and 5 of my keyboard directly, and got that same rounded off shape instead of nice clean pulses, that might mean that my keyboard's MIDI out is faulty. Ugh... if that's the case then I'm SOL until I get some other device with MIDI out to do some testing with. Is MIDI supposed to be a high signal that's brought low to send a signal, btw? I thought it should be low and go high to send a signal.
@ISB123 : Thanks, will do.
IWorkInPixels
Joined Sep 25, 2015
55
  • Logic 1 → High → no current flow → Opto-isolator LED off → MIDI receiver sees High, logic '1' (data bits, stop bit or idle)
  • Logic 0 → Low → current loop flow → Opto-isolator LED on → MIDI receiver sees Low, logic '0' (data bits, start bit)
    That bit seems to suggest that this is wired backwards, and I am indeed looking for low that goes high whenever I press a key, no?
    The layout calls for the pins to be wired as they are, but reversing them would invert the logic.
IWorkInPixels
Joined Sep 25, 2015
55
Just did... looks like it goes in on pin 2 of the atmega, which is the RX pin, so that checks out... and it looks identical to probing it at the resistor next to the optoisolator. Same waveshape and amplitude.
kubeek
Joined Sep 20, 2005
5,796
One bit should be 32us long, so you might try making the timebase faster and see if there is anyhting that looks more like a proper signal. Also, is that resistor really 270 ohms?
IWorkInPixels
Joined Sep 25, 2015
55
Any ideas why my scope would show the MIDI signals like that? Is my probe just calibrated wrong? I went through the scope's self-calibration, and the internal signal generator's square wave already looks square down to about 50ns, after which the wave ramps up to the right, and no amount of turning the adjuster in the probe will affect it one way or the other.
Alec_t
Joined Sep 17, 2013
15,121
What opto-isolator are you using? It needs to be a fairly high-speed type. The waveform shows signs of a slow one.
Can you post a schematic of the MIDI input section of your synth?
IWorkInPixels
Joined Sep 25, 2015
55
I did... coming in from the MIDI cable looks identical, and if I program my UNO to think it's a MIDI device it looks the same on the scope. I'd say my probe wasn't calibrated right, but it reads the test squarewave on the scope just fine.
