I have a problem with my Roland Synth which keeps rebooting after 10 or 30 minutes, I have read it may be a bridge rectifier. I have located a 4 pin bridge rectifier, and tested it with a multi-meter. When I test each pin, by putting the negative multi-meter on the + bridge rectifier and then put the + multi-meter and test the two middle pins I get around 570 on each pin, but I dont get a doubling when i put the + multi-meter on negative bridge rectifier, I get 750, could this be the problem, should it be higher?
