I understand the video, however i still do not noe how to solve the problem because it appear the sequence of the states is different due to the condition on the question!~
This isn't too bad because they are D flip-flops and they are all synchronized (clocks are all the connected). They are all positive-edge triggered. So to simplify all this, they are all going to change at the same time.
Initial Conditions:
Qc = 0
Qb = 0
Qc = 0
So, since these are positive-edge triggered D flip-flops, every positive edge of the clock will cause all the D's to pass their values to the Q's.
So, the next rising edge will cause:
Qc = Dc
Qb = Db
Qa = Da
The D values are calculated from the previous Q values.
Dc = Qa + Qb
Db = Qa'Qb + Qc'
Da = QbQc
So given that the first sequence is 000, the following will occur before the next rising edge of the clock:
Dc = 0 + 0 = 0
Db = 0'0 + 0' = 10 + 1 = 1
Da = 00 = 0
These values are then passed to the Q's on the next rising edge of the clock, then the process continues.
Try it out yourself, but this is what you should get:
000
010
110
111
101
100
000
...repeat
So now that we know the pattern, you can find out what the output would be at any amount of rising clock pulses.
