Symmetrical, adjustable voltage source from 0 to 15V, with adjustable current limiter up to 2A per channel.
jaimesorte
Joined Feb 25, 2022
7
I am a recent graduate in electronics, and I am working on an adjustable symmetrical voltage source with a current limiter that remains stable for any capacitive load. Since I am a recent graduate, I would appreciate assistance in analyzing this circuit. I would like to understand why the circuit oscillates when the output capacitors (C1 and C2) are removed and how these capacitors placed there ensure the stability of the power supply. I would also appreciate an explanation from someone more experienced regarding current and voltage control, as well as an overview of the general operation of the power supply.
Attached is the power supply simulated in LTspice and its corresponding library so that you can simulate it if you wish.
The complete power supply circuit (without the linear power supply) is used for simulation. I am still unsure why I can't simulate with the complete power supply circuit (with the linear power supply).
The entire library is too large to be shared here. So, I have uploaded it to Google Drive, and I will leave the link here for you to download.
https://drive.google.com/drive/folders/13cNf8YzybxsezZxV_cqKbCpJ0NyOv_CS?usp=sharing
dl324
Joined Mar 30, 2015
18,481
Welcome to AAC!
Please post a schematic so we can see how the capacitors are being used.
Are you certain that the simulation is working correctly?
jaimesorte
Joined Feb 25, 2022
7
Welcome to AAC!
The schematic is available both in the provided Drive folder and attached to this post. The simulation runs with my library in LTspice. Remove your entire library and replace it with mine. Don't forget to make a backup of yours before doing this. The LTspice library is typically located in C:\users\yourUser\AppData\Local\LTspice, and it is a folder called 'lib'
schmitt trigger
Joined Jul 12, 2010
2,260
Basic negative feedback control theory. Your closed loop gain must be below zero dB before the phase shift reaches an additional 180 degrees.
Have you made a Bode plot?
jaimesorte
Joined Feb 25, 2022
7
We start with a linear power supply capable of delivering approximately +30V at +B and -30V at -B.
This part of the circuit indicates that the power supply is on.
Here, we generate the voltages of 5V and 10V, which are auxiliary supplies for powering the ICs and potentiometers.
Here, we generate the voltages of -10V, which are auxiliary supplie for powering the ICs.
Here we have a comparator circuit to indicate current overload on the negative output.
Here we have a comparator circuit to indicate current overload on the positive output.
Below, we have the circuit that regulates the voltage using a potentiometer.
Below, we have the negative part of the power supply.
Below is the positive part of the power supply.
Notice in the upper photo's corner the current limiter through a potentiometer. Below, enlarged.
38,885
The maximum current through the Zener is 20V / 220Ω = 90.9mA which will cause 909mW dissipation in the 250mW Zener, so it won't last long.
(You can see that in your simulation by doing an ALT-Left Click over the Zener after doing a transient or operating point simulation).
Why not use an LM7910 negative regulator for that?
jaimesorte
Joined Feb 25, 2022
7
Actually, this zener diode is 10V 1W.
I used what was available in the simulator at the time of simulation.
jaimesorte
Joined Feb 25, 2022
7
Thank you for the tip. I studied the theory and created the Bode diagram.
Now I understand
I have one more question. How can I understand the current control by the transistors T4 and T5?
