Symmetric 555 oscillation
lotusmoon
Joined Jun 14, 2013
232
Mod edit: This thread was split from here: http://forum.allaboutcircuits.com/showthread.php?t=86130
Please do not hijack other members' threads.
I am new to electronics, but wanted to make a strobe with different frequencies.
I have this formula for a 555 timer cycle
t1 = .693 x (R1+R2) x C
t2 = .693 x R2 x C
t1 = time on and t2 = time off
from this formula it does not seem possible to have an equal t1 and t2. could some one let me know if there is a way to have them equal?
33,192
t2 = .693 x R2 x C
Please don't hijack someone else's thread as it creates massive confusion. Instead, start one of your own. Don't do that now, though; I've reported your post and a moderator will probably split it off into its own thread in the near future.
This is a question that has been addressed many times and in many places here. I don't have a specific link to give you, but search the forum (and also the blogs) for something like "555 equal on off" or "symmetric 555 oscillator" and you will probably find something quickly.
THE_RB
Joined Feb 11, 2008
5,438
It's best to use a different circuit. There is an astable 555 timer circuit driving the threshold cap from pin 3 (does not use the discharge pin 7).
That circuit is simpler and gives a good 50% duty cycle at all speeds (especially with CMOS 555 chips like the 7555).
ErnieM
Joined Apr 24, 2011
8,415
t2 = .693 x R2 x C
Correct, but if you make R2 much greater then R1 then the on and off time get very close in time.
lotusmoon
Joined Jun 14, 2013
232
"It's best to use a different circuit. There is an astable 555 timer circuit driving the threshold cap from pin 3 (does not use the discharge pin 7).
thank you"
thank you - do you have a link to this circuit circuit?
KL7AJ
Joined Nov 4, 2008
2,229
t2 = .693 x R2 x C
Indeed it is not, but you can make it very close to symmetrical by making R1 very small relative to R2.
Eric
35,180
Symmetrical clock signals are rarely a necessity.
To create a symmetrical signal from a 555 timer circuit, output a signal at twice the desired frequency and feed it into a toggle flip-flop (T-type flip-flop).
You can use a D-type or J-K flip-flop to create a toggle flip-flop.
lotusmoon
Joined Jun 14, 2013
232
Nah, you don't need those messy diodes. :)
Here's the circuit, it only needs a 555, 1 resistor and 1 cap;
If you replace the resistor with a pot and resistor in series you get variable frequency but still has 50:50 duty cycle.
That's brilliant I wanted a variable frequency. is possible to work out and fix the beginning and end of the variable frequency? ie 1Hz - 100Hz
THE_RB
Joined Feb 11, 2008
5,438
Yep. If you use a 1k resistor in series with a 100k pot, the frequency adjustment range will be approximately 100:1.
As for the actual Hz, try plugging in different caps (and you may need two caps in parallel) until you get roughly 1Hz to 100Hz.
lotusmoon
Joined Jun 14, 2013
232
I have been told capacitors are up to 20% inaccurate which would make it hard to accurately calculate the frequency is this true?
THE_RB
Joined Feb 11, 2008
5,438
That's part of it, and the 555 output will have some impedance that will also affect the calcs.
Just plug in some different caps, it's very fast to test and settle ona cap value. Example; If your first cap runs 5 times too fast you know you need a cap about 5 times larger.
