SX1280 TCXO/ Crystal versus Power Mode
joseph20480
Joined Nov 15, 2023
9
Dear community,
I have developed a board with SX1280 and i meet some difficult.
In fact, the clock signal on crystal (52Mhz) make "pause" often ( maybe each transmit).
My configuration :
1. internal DC-DC power instead of Internal LDO
2. Crystal Osc 52Mhz instead of TCXO (52Mhz).
Capture d'écran 2024-02-27 162945.pngI try to debug my board with help of SX1280 evaluation board( no problem with the eval board).The only difference :
>> TCXO instead of Crystal . (power mode is the same).
My question, do you have already use the SX1280 on crystal AND with DC-DC power mode ??
There is no information in datasheet... i'm lost.
jrb_sland
Joined Dec 24, 2021
25
Dear community,
My configuration :
View attachment 316421I try to debug my board with help of SX1280 evaluation board( no problem with the eval board).The only difference :
All the TCXOs I have ever used have at least three active pins, i.e. VDD, GND, and OUT [or Fo = signal out]. Your schematic doesn't show a Vdd connection [often a separately regulated precision 3.00 volts] for your part labelled "XTAL4" .
Page 17 of the Semtech data sheet*** for the SX1280 labels pin 4 as either XTA [of the XTA/XTB simple crystal connection that I see in your schematic] or as the input from a TCXO, with no connection to pin 6 [XTB]. See the suggested schematic in Figure 15.3 on page 147 of the data sheet showing decoupling ferrite beads & a 100 nF bypass capacitor on the Vdd input & the 1 nF output coupling capacitor. Does the SX1280 require setting up [programming] an internal control register to distinguish between crystal & TCXO operation, or does it auto-detect the crystal?
The DC/DC power mode should not be related at all to the crystal/TCXO operation, but I've not studied the SX1280 data sheet in depth in its entirety. That is your job. Hope this helps!
*** https://media.digikey.com/pdf/Data Sheets/Semtech PDFs/SX1280-81_Rev3.2_Mar2020.pdf
joseph20480
Joined Nov 15, 2023
9
thanks for your reply.
1. "The DC/DC power mode should not be related at all to the crystal/TCXO operation "
You have right, i haven't read information about this... but..
2. TCXO need power supply, crystal not. My orginal schematics works with simple crystal. I have to try with a TCXO (and little modification on my prototype).
