Switching rgb led lighting
Cavester
Joined Sep 5, 2017
hi,
I just wanted to double check this if possible.
I have a controller that currently I am using a doorswitch to turn on and off, but then when I open the door I also have to operate the controller each time. My thought is to switch the common on the led circuit to leave the controller permanently powered. Will this work ok?
