Switching noise on PWM input and other Digital signals
beera beer beera beera
Joined Dec 16, 2016
25
When we are enabling PWM , we are observing switching noise on PWM signals as shown in capture. While IGBT on transition (VCE – 192V ->0)/ IGBT off transition(VCE-0V -> 192V) , we are observed this switching noise. (6 gate drivers are used for driving the IGBT module (6 IGBTs)). Can any one suggest how can I decrease this switching noise ?
Alec_t
Joined Sep 17, 2013
15,167
If a heavy current surge/change as the IGBT switches is affecting the PWM supply, that might be getting through to the PWM drive signals. Do the gate driver and IGBT supplies share any common trace, or do you have a star-ground setup?
Joined Dec 16, 2016
25
Hi ....Thank you for your support. We are having separate grounds for HV side of Gate driver + IGBT and LV side of Gate driver. Also each gate drivers are having separate isolation.
