Switching common anode RGB led?
Ian0
Joined Aug 7, 2020
13,283
I'll make a different suggestion:
Get four 74HC125 buffers to drive the LEDs, and multiplex them using the output enable pins.
k1ng 1337
Joined Sep 11, 2020
1,038
is this not what I'm trying to do? My task would then require 3 of these chips, " Sinks or sources 4mA at VCC = 4.5V " and Schmitt trigger
ericgibbs
Joined Jan 29, 2010
21,577
arduino digital outputs, 12 numbers, 12 bit display, infinite possibilities
hi K,
I would like to help, perhaps if you explained what is the purpose of project, we could suggest better alternatives.
E
k1ng 1337
Joined Sep 11, 2020
1,038
hi K,
E
The goal is of this project is to make an Arduino real time clock with an 8 bit display, whatever leftover space left in the ROM will be fun LED patterns. Then I plan to make a minamal arduino with just the atmega328 chip as a standalone LED driver. This project is about learning arduino not the best LEDs ever haha. From there I can revise how the LEDs are driven. I have a ton of junk and buying more costing money, who has time for that?
