Switching between two lights with a momentary signal from buttons
jfedorek
Joined May 3, 2020
7
Moderator's note: This thread is a branch from: https://forum.allaboutcircuits.com/...h-2-latching-relays.85237/page-3#post-1509070
The circuit will remain in whatever state you leave it until you press the button a second time. You will have to add a "power start" circuit if you want it to start in a certain state. Otherwise a J-K Flip Flop is stable until you change an input.
. I am also trying to do a similar idea that I can not figure out. I would like to install indicator light on my kato turnouts. I would like the green light on the track that’s open and a red light on the one that is not. They are a signal coil that only uses momentary power to move the turnout. Reversing polarity moves it back. Can this be done some how ? They are twined together so I am using 18 volts dc with a dual button board.
CA1F25EB-154E-4513-A093-F2B55E5A241C.jpegStuck here because I can’t figure out how to get lights to stay on with momentary power only
jesse
KeithWalker
Joined Jul 10, 2017
3,614
View attachment 206514Stuck here because I can’t figure out how to get lights to stay on with momentary power only
jesse
See my reply on your thread about model railroad turnout indicators..
Keith
