Switching between two LEDs with two different supply voltages
3Phase615V
Joined Dec 6, 2019
13
I am trying to get this circuit to work better in terms of LED brightness and ensuring either LED is not lit when the other is. The LEDs are 5mm red (1.8 - 2.2V, 20mA) and blue (3.2- 3.8V, 20mA) LEDs as shown.
The 6.25V supply is constant, i.e. not switchable, but the 8V supply has a momentary switch, as shown. In theory the red LED should extinguish while there is power to the blue LED on the 8V rail, but in reality it glows a little. Furthermore, in order to limit the glow of the red LED I had to increase the value of R1 to 270R from 220R, but of course this limits the current supplied to the blue LED so it gets about 16mA rather than nearer 20mA. This also means the red LED is dimmer receiving only about 10mA. I am guess I may need a transistor to switch the power between the LEDs but asking for any suggestions, including adding transistor(s).
Tonyr1084
Joined Sep 24, 2015
9,744
8V - 3.5Vf = 4.5V
4.5V ÷ 270Ω = 16.7mA (16.666•••mA)
6.25V - 2Vf = 4.25V
4.25V ÷ 270Ω = 15.7mA (15.741mA)
Using both average forward voltages for each LED (Vf), the numbers work out to a difference of 1mA. Given the chances that the Vf of each LED, there's a possibility that the red LED is still seeing some current. Even that 1mA can be enough to cause the red LED to glow very faint. I've seen LED's light with as little as 5mA. Not saying below that is not possible, that's just been the sum total of my experiences, I've lit LED's with that low a current.
Is this circuit just an exercise? Or are you attempting to accomplish something particular? Tell us what your goal is and we can help.
Tonyr1084
Joined Sep 24, 2015
9,744
Single 6.25V supply
Two resistors 270Ω
Blue LED Vf 3.5
Red LED Vf 2.0
Momentary switch
Push the momentary switch and the blue will extinguish and the red will illuminate.
My approach:
3Phase615V
Joined Dec 6, 2019
13
Hi, Thanks for replying to my post.
Yes, this is for a backlight on a transceiver analogue meter to indicate when the radio is in receive and transmit modes. In addition to ensuring LEDs are either fully on or off, I would like them at their maximum brightness (~20mA, without overdriving them) for maximum visibility of the meter scales.
sghioto
Joined Dec 31, 2017
8,634
If it's used in a transceiver shouldn't there be a voltage you can used that is OFF in the transmit mode?
Assuming the RED is for receive and the BLUE for transmit?
3Phase615V
Joined Dec 6, 2019
13
Thanks Tony. The 8V rail switch forms part of the PTT switch so I don't really want to have to add another switch as this would be a rather more complicated approach for the radio.
Thanks for your suggestion Eric. I was hoping to somehow gain some current through both LEDs to bring them nearer 20mA as well as dealing with the unwanted glow from the red LED.
Tonyr1084
Joined Sep 24, 2015
9,744
Reduce the size of the resistor. 20mA (RED LED) will require a resistance of (6.25 - 2) ÷ 0.02 = 212.5Ω. Use a 200Ω resistor and you'll have 21.25mA. The blue LED will be running a current of 13.75mA. But the blue LED is likely going to LOOK brighter than the red LED. If you drop the resistance even further, I wouldn't exceed 30mA on the red LED. Since it sounds like you'll be receiving longer periods of time than you would be transmitting, running the red LED occasionally at 30mA isn't going to shorten its life significantly. 30mA (red) requires 142Ω. At 142Ω the blue will see 19mA. Close to 20mA. The closest resistors to that value would be 150Ω. So red would be 28mA and blue would be 18mA.
3Phase615V
Joined Dec 6, 2019
13
Yes, the 8V rail switches the blue LED off through having the PTT depressed allowing the red LED to light. What I would like is to increase the current through both LEDs while maintaining the binary state of light between the two LEDs.
Tonyr1084
Joined Sep 24, 2015
9,744
Then I wouldn't worry about the red being ever so slightly illuminated. The red and blue mixed together will give a purple(ish) color. But you probably won't even notice it at all.
3Phase615V
Joined Dec 6, 2019
13
Thank you, Tony. If you mean in my circuit, I already tried with a 220R resistor and although the blue LED meets ~20mA while on in Rx mode the red LED is even brighter as more current is allowed through it. Sorry, I may have caused confusion with my momentary switch showing o/c rather than continuity, as sghioto pointed out. It's true that the red LED is not hugely affecting the overall colour of the blue in this condition but it looked a bit cowboy to me if I left it that way and someone else came across this mod, perhaps with more experience.
