Hi, I'm working on a circuit which can either be powered via a Micro-USB, or a pre-regulated 5V input. If both are present I want the 5V to come from the regulated source.
I need some help finding a simple circuit which can help me accomplish this.
I've seen one variant which just uses a diode in series with each input, but that will incur a small voltage drop which I would like to avoid.
I've also seen a couple of variants which uses opamps and p-channel mosfets, but those seem to require that the input voltage is higher than 5V.
How can I build a circuit that takes in 5V from one or two sources, and outputs 5V?
