Switching Adapter Repair: What is this clip?
kelaboy
Joined Mar 3, 2017
20
Opened up a switching adapter to solder a mains wire that had come off. This metal clip, in half a square inch of foam rubber, fell out of the enclosure; marked in the first pic.
What would this be? Is it hold down the big cap ?
dl324
Joined Mar 30, 2015
18,469
Brightened picture:
Have you tried fitting it over the likely components? Does the other half of the enclosure show any residue/depression from the foam?
Manufacturers aren't in the habit of using unnecessary parts, so I'd try to put it back where it was intended.
dl324
Joined Mar 30, 2015
18,469
The other half has two more foam tabs. Tried placing it over all likely components - no luck.
I can't tell from the glare in the picture whether there's any residue to show where the foam piece might have been.
It has to fit somewhere.
