Hello friends,
My car's cigarette lighter/charging socket (12V) always remains ON, even after locking the car. But the pen-drive attached to its music system gets activated only when car is in accessory mode or its ignition is turned ON. What basically I want is to turn charging socket (12V) ON as soon as music system gets activated and should be turned OFF as soon as music system gets deactivated(Upon exiting from car).
With a little knowledge of electronics I know that USB's are powered with 5V DC. Can someone help me to use this USB power to trigger 12V lighter circuit? I feel this can be done using some Transistor (probably NPN). Which transistor should be used and what will be its circuit diagram?
Thanks..
Thanks..
